Brand new unplugged in. RRP $5980  they sell for a lot more elsewhere so very good price in Aus.  2 litres of cleaning fluid inc.
https://sonicpurity.com.au/store/vinyl-care-accessories/hannl-mera-professional
I searched long and hard for the best and closest to fully automatic record cleaning machine in the world and came across they stunning almost quiet RCM from Germany. Its unopened and comes with 2 bottles of dedicated cleaning liquid a litre each think . Ultra easy to set up and use and run in a normal room as it does not sound like a jet engine.
I have about 2000 albums and some really bad ones to clean but have decided to use a friends service instead on the bad ones and sell this and maybe run a cheaper ultrasonic bath version in the garage..
 I have no real space for it and as its so stunning it can sit next to your turntable or on a rack, this was my idea but changed audio room around and no space to incorporate it and its too nice to hide in a garage.
Freight not included but $100 should cover it insured Aus wide.
If you are looking for something solid and special Hannl Mera Professional could be the right choice for you. Based on a classic and bestseller, this machine has been completely redesigned and adapted to today's requirements.
DESIGN
The housing of the HANNL Mera Professional is made of 10 mm black high gloss carbon acrylic. Metal elements, such as the side struts, the feet, the heavy puck, etc. are CNC machined and hard chromed. They give the machine a timeless, high-quality design.
THE HANNL ROUND BRUSH
Unique feature of this high-quality machine is the patented HANNL round brush, which was developed by Günter Hannl. With the round brush a gentle deep cleaning of the record is achieved. Customers repeatedly report unique results on otherwise abandoned records. Watch our video on this page.
INDIVIDUAL SETTINGS
Traditionally, the Hannl Mera is appreciated by vinyl lovers because it allows individually adjustable plate washing. This concept has been retained. With the Hannl Mera Professional you can adjust the dosing quantity, the turntable speed and also the performance of the extraction turbine to your personal requirements. You can even adjust the brightness of the LED display to your comfort level and disable acoustic signals. And best of all, your machine remembers your preferences and automatically makes your settings available at the next plate wash. Such an individuality offers you no other plate washing machine!
THE NEW AUTOMATIC MODE
The concept of individual record cleaning was complemented by an automatic function in the course of redesign. This makes the HANNL Mera Professional an all-rounder. In automatic mode, a defined amount of liquid is automatically dispensed. A washing timer monitors the optimal washing time and reports when the discharge should be initiated. The drying process starts at the push of a button and ends automatically after a change of rotation. The practical LED bar display shows you the respective progress. The automatic mode considerably simplifies the rapid processing of larger collections.
A classic, completely redesigned
