On 17/09/2022 at 4:57 PM, wartman said:
This came with a turntable I purchased.
No idea what it is.
Hi Wartman,I have the same tonearm but with on original headshell ,would you mind to post a pic of yours ?
( Mine came with a sansui one 😒)
Cheers.
On 18/09/2022 at 12:59 AM, zenikoy said:
OK I need some help IDing this one.
Deffo Acos Lustre GST 1, I have one fitted to my Luxman PD264.
Guest Mr Thorens
1 hour ago, wartman said:
S-220 tone arm.
Headshell pics
Also found the original specs.
Interesting it has a different counterweight to the usual square one for this tonearm.
I have two of these.
Both counterweights are round with a flattened top.
This is my Acos Lustre GST 1 . Showing head shells.  I also had one fitted to a Rega.
1538155255_AcosGST12.thumb.jpg.c54a8c7a4cf1f49594f8ab0b497da7c8.jpg71047773_AcosGST13.thumb.jpg.1251a19a46a26d34d8df6bd3618d80c4.jpg
Edited by EV Cali
Thanks Wartman ,that headshells are hard to find ,they look much industrial than the normal ones with all the cutouts,love them.
EV Cali I am surprised to see that your tonearms look brand new but you have Linear Design headshells ( don't remember how many times missed to get one of there TTs on the cheap to get that tonearm ,specially the sound tracer ones..they just avoid me)
6 hours ago, wartman said:
S-220 tone arm.
Headshell pics
It looks like the armlift on the headshell has been pulled forward, on the illustration it is perpendicular to the headshell side.  It wouldn't be too difficult to gently bend it back into position.
Guest Mr Thorens
They’re a great tonearm that’s for sure.
Great tonearm
The rarest thing on a S-220 is the lifter only seen a couple of pics ...guess it's an aftermarket add on but really would love to put my hands on one ( maybe one day I make one,btw when bought the Silex was hopping I could scavenge the lifter of the tonearm for that )
Thanks tango.
That lifter would be really helpful.
I'll see what I can find.
