obama Posted September 26, 2022 Posted September 26, 2022 Looking to change my ported box to sealed enclosures. X2 um18-22 Does anyone know who specialise in this area? Iv talked to some cabinet makers but they have no clue.
Quark Posted September 26, 2022 Posted September 26, 2022 (edited) John Woodhead at Aranmar Acoustics should be able to help - he makes Osborn Speakers cabinets. There tends to be a *long* lead time when they're busy. No sure if John does unfinished boxes if that's what you want - the work I've had done has been veneered to a very high quality and not cheap. Photo now added of a cabinet built to match my Osborn speakers - has lots of reflections and colour is a bit off, but gives you an idea of the quality. Edited September 26, 2022 by Quark Added photo 2
Yamaha_man Posted September 26, 2022 Posted September 26, 2022 https://instagram.com/torquay_audio?igshid=YmMyMTA2M2Y=
obama Posted September 26, 2022 Author Posted September 26, 2022 Thanks guys. Il check them both out.
BenBenBen Posted November 9, 2022 Posted November 9, 2022 Did you get some sealed cabinets built? If not, have you considered blocking the ports, and they'll act like sealed. That'll at least give you an idea if you're happy losing the output around port tune.
Special K Posted November 9, 2022 Posted November 9, 2022 On 26/9/2022 at 12:06 PM, Quark said: John Woodhead at Aranmar Acoustics should be able to help - he makes Osborn Speakers cabinets. There tends to be a *long* lead time when they're busy. No sure if John does unfinished boxes if that's what you want - the work I've had done has been veneered to a very high quality and not cheap. Photo now added of a cabinet built to match my Osborn speakers - has lots of reflections and colour is a bit off, but gives you an idea of the quality. Second on the work that John does. Only had some front baffles done so far however the service and quality are worth the spend.
