Berj Varjabedian Posted October 25, 2022 Posted October 25, 2022 Further info: Floor standing pair of high resolution Sony speakers. Built for the new standard of audio these floor standing speakers play music to 40000hz. With 6 speakers built into each speaker box and at 18kgs each, these are wonderful speaker which was just under $2000 retail price when purchased. Condition: essentially brand new, not a scratch! They have always been in the same spot. Strong box with nice open midrange and sweet treble, great for small to medium size rooms. negotiable What Hifi review says: The new speakers come in the form of the SS-AC3 three-way, six-driver floorstander (above) which aim to bring concert-quality sound into the home. An "immensely strong" 30mm baffle board joined to the rear enclosure is at the heart of the SS-AC3 in a bid to reduce internal vibrations, while a 13cm woofer with aluminium diaphragm is also found inside. Mid-range and tweeter units have their own "acoustically isolated" enclosures, separate from the woofer cabinet space with their own reflex port in a two-part design that reduces the effects of air pressure. Meanwhile, Sony's I-ARRAY System is on board to supplement a 25mm soft-dome main tweeter with two 19mm soft-dome assist tweeters to increase the "sweet spot" at higher frequencies. See specs below. ENCLOSURE TYPE Bass reflex FRONT SPEAKER SENSITIVITY 86dB (2.83V/m) FRONT SPEAKER TYPE Passive FRONT SPEAKER INPUT TERMINAL Binding post FRONT SPEAKER UNITS: FULL RANGE 1x 130mm full range FRONT SPEAKER DIMENSIONS (W X H X D) 197 x 960 x 295 mm FRONT SPEAKER FINISH Wood FRONT SPEAKER UNITS: WOOFER 2x 130mm aluminium cone woofers FRONT SPEAKER UNITS: TWEETER 1x 25mm + 2x 19mm soft dome tweeters FRONT SPEAKER MAXIMUM INPUT POWER 100W FRONT SPEAKER MODEL NAME SS-AC3 FRONT SPEAKER RATED IMPEDANCE 6 ohm 1
yobs Posted October 25, 2022 Posted October 25, 2022 Nice price. The midwoofer looks like it's from the scanspeak revelator series (which is a great driver). GLWTS
Berj Varjabedian Posted October 25, 2022 Author Posted October 25, 2022 2 hours ago, yobs said: Nice price. The midwoofer looks like it's from the scanspeak revelator series (which is a great driver). GLWTS Yes, I believe so, I never pulled apart.
Guest Posted November 1, 2022 Posted November 1, 2022 This advertisement has been reported as Sold Elsewhere.
