Further Information: Today we have a Yamaha DSP-A1 AV Receiver in good secondhand condition. This former flagship is no slouch in terms of amplification power being rated to deliver 110 watts per channel into 8-ohm loads to the five main channels and 35 watts to each of the front-effect channels. The processor provides 42 possible programs including Dolby Digital, DTS, Dolby Pro Logic, Yamaha's proprietary Tri-Field Processing, Cinema DSP, and Hi-Fi Digital Sound Field Processing.
Specifications:
Power output: 110 watts per channel into 8Ω (stereo)
Surround output: 110W (front), 110W (center), 110W (rear)
Frequency response: 20Hz to 20kHz
Total harmonic distortion: 0.005%
Damping factor: 200
Input sensitivity: 2.5mV (MM), 150mV (line)
Signal to noise ratio: 86dB (MM), 96dB (line)
Channel separation: 60dB (MM), 60dB (line)
Output: 150mV (line), 1V (Pre out)
Digital inputs: coaxial, optical
Video Connections: composite, SVHS
Dimensions: 435 x 191 x 473mm
Weight: 23kg
