andyr Posted January 29, 2023 Posted January 29, 2023 2 hours ago, 075Congo said: I have connected both my audio components currently using signal ground not chassis grounding and am very pleased with that option. Do you mean by that ... that you have disconnected the wire inside the component cases which would've connected the earth lug of the IEC socket to the case ("safety earth")? Or don't your components use 3-wire mains cords?
Neo Posted January 29, 2023 Posted January 29, 2023 (edited) I’m out of this topic Neo Edited January 29, 2023 by Neo
075Congo Posted January 29, 2023 Author Posted January 29, 2023 No I have not touched the internal wiring only connected the SGS 1 Signature box to signal grounds (RCA plug) on the rear of each component. 1
andyr Posted January 29, 2023 Posted January 29, 2023 1 minute ago, 075Congo said: No I have not touched the internal wiring only connected the SGS 1 Signature box to signal grounds (RCA plug) on the rear of each component. Aah, OK. Thanks for the clarification.
