thejt Posted January 8, 2023 Posted January 8, 2023 Further Information: Made by Mark on the forum this is a class AB chip amp with ~100W per channel. Beautifully made with a nice bounce and excellent bass. I was using this paired to a Yamaha WXC but have simplified to a Yamaha WXA which has an inbuilt amplifier so no longer required. Links to Mark's blog and original listing for more info. http://retro-thermionic.blogspot.com/2021/05/cello-tda7293-chip-based-100w-amp.html
MIKE.D79 Posted January 18, 2023 Posted January 18, 2023 Good morning thejt. Im currently looking at a power amp, but don't really know much about class A/B design or chip amps. Basically I'd be running SET tube pre amp in front of it, speaker would be ascension summoners 180 watt 6 ohm, 91 DB sensitivity. Just wandering if this would be a bit a bit under powered to drive these speakers well? I'm also thinking i might pick marks brain regarding this. Thank you and look forward to your reply.
