jamesy1987 Posted January 13, 2023 Posted January 13, 2023 Further Information: full working condition, comes with all three adaptors. Just over a year old. I have gone bluetooth so have no need for this cable sounds beautiful, will be missed for more info on the cable: https://addictedtoaudio.com.au/.../fiio-lc-re-pro-mmcx...# South Melbourne pickup or I can post Description Flagship material-gold, silver and copper braided in one cable To achieve optimal sound quality, one has to consider everything starting from the cable wire materials. The LC-RE Pro consists of three kinds of wires, Furukawa monocrystalline copper, gold-plated monocrystalline copper, and pure silver. All three kinds of wires go through ultra-high temperature continuous casting after secondary smelting to be of the highest quality. As a flagship-grade braided headphone cable, the LC-RE Pro settles a matter at one go. Careful upgrade with stainless steel angled MMCX connectors The luxurious texture of the LC-RE Pro benefits from the craftsmanship from inside out-the expanded MMCX connectors featured on the LC-RE Pro ensures great reliability; the ergonomic angled design provides a more comfortable wearing experience. In addition, the medical-grade 316L stainless steel was used at the audio plug, which redefines what a flagship headphone cable is. 4 strands, 240 wires Each strand of the LC-RE Pro consists of 20 gold-plated + 20 pure silver + 20 monocrystalline copper wires. 4 strands in a total of 240 wires achieves better conductivity that presents rich musical details. Specialised handling in a Litz braided style The cable wires are all braided together in the Litz style. This greatly minimises the adverse skin and proximity effects and thus reduces the resistance of the wires, letting signals travel through the wire more easily and purely, improving high-frequency resolution in your music. Freely switch between different audio plugs The LC-RE Pro features twist-lock interchange audio plugs, allowing you to freely switch between 3.5mm single-ended / 2.5mm balanced / 4.4mm balanced plugs depending on your source. Carefully selected cable sheath, transparent German TPU material The outer sheath of the cable is made from environmentally friendly German TPU material, with a lustrous transparent look. As added bonuses, the TPU material is also resistant against yellowing after long-term use and against stiffening when in low-temperature environments. Quick and easy "left blue right red" unit markers The "left blue right red" unit markers help to quickly identify how the earphone unit should be connected, thus making for a smooth music journey. Features Gold, silver and copper wires Twist-lock swappable audio plugs 4 strands, 240 wires Litz braided Stainless steel MMCX connector Specifications Ear Hook Over-the-ear Core Material Gold, silver and copper braided Wire Count 4 strands in a total of 240 wires Wire Structure Litz braided Cable Length About 120cm (excl. the plug) Cable Sheath Transparent German TPU Connector (headphone end) Expanded MMCX Connector (source end) Swappable 3.5mm single-ended / 2.5mm balanced / 4.4mm balanced
