strangeloops66 Posted February 17, 2023 Posted February 17, 2023 Further information: TDL RTL 3 Special Edition. Enclosure Type: 2-way reflex transmission line loading Recommended Amplifier: 20 - 120 Watts Frequency Response: 35Hz - 20kHz Crossover Type: Electrical 2 way second order network Sensitivity: 90dB Nominal Impedance: 8 Ohms Drivers: 1 x 19mm soft dome ferro-fluid cooled 2 x 172mm loaded polypropylene cone with forward roll rubber surround & phase plug - long throw double wound coil on kapton former with bump back magnet yoke Dimensions: 200 x 888 x 375mm (Width x Height x Depth) Weight: 21kg Year: 1995 British manufactured and a star in their day. Hybrid reflex transmission line design, with great bass extension (down to 35Hz). See review The foam plugs for the transmission line ports on the front of the speaker have been replaced, as has the grille of the centre speaker. "Transmission Line loudspeaker systems incorporate a complex and potentially expensive method of reproducing lower bass frequencies than other speakers of a similar size. This bass is open and unrestricted, in a manner simply not achievable from conventional sealed box speakers." TDL Nucleus 1: Bookshelf 2-way stereo speakers, 26 cm high. Infinite baffle design, 50watts, 8ohm impedance, 89db sensitivity. Speaker terminals facilitate bare wire or banana plugs. Original removable grilles in good condition with badges intact. Beautiful vinyl veneer enclosures in black Ash. http://www.hi-fi-insight.com/tdl-nucleus-1-bookshelf-loudspeakers.html TDL CCS centre speaker
Tamon Posted February 17, 2023 Posted February 17, 2023 Awesome speaker I have the rtl3 and enjoy every time I listen to them . Bottom end is superb . Bargain. 1
simonf Posted February 24, 2023 Posted February 24, 2023 Id like to purchase your speakers. PM sent. Thanks.
