Famo Posted February 17, 2023 Posted February 17, 2023 Item:Pioneer Plasma PDP 509 TV Remote Price Range: Will pay any reasonable asking price Item Condition: New Or Used Extra Info:My Pioneer TVs remote has failed and new to replace it to access settings
JohnL Posted February 17, 2023 Posted February 17, 2023 Happy with cheap Chinese clone or want genuine Pio?
Famo Posted February 17, 2023 Author Posted February 17, 2023 prtewfer genuine article because my original remote won't open settings tab
JohnL Posted February 17, 2023 Posted February 17, 2023 https://www.ebay.com.au/sch/i.html?_from=R40&_nkw=pioneer+axd+1570&_sacat=0&LH_PrefLoc=2&_sop=15
JohnL Posted February 17, 2023 Posted February 17, 2023 (edited) Hi, When you open the link below and also click on the pic you will see your remotes model number according to Remote Control Warehouse. https://remotecontrolwarehouse.com.au/products/original-pioneer-remote-control-axd1570-pdp-lx508a-pdplx508a-flat-panel-display?_pos=1&_sid=12eca6f13&_ss=r&variant=31280954540121 If purchasing from Ebay you may want to confirm compatibility with Seller. I don't want to give you a bum steer!!!!!!! Good Luck Edited February 17, 2023 by JohnL
Mr 57 Posted February 17, 2023 Posted February 17, 2023 I bought a Chinese remote for my Pioneer, worked straight out of the box
frednork Posted February 17, 2023 Posted February 17, 2023 My next door neighbor popped a pioneer plasma and remote on my hard rubbish pile. When I get a chance I can grab it and see if it suits. You can have it gratis if it suits.
Famo Posted February 17, 2023 Author Posted February 17, 2023 Thank you so much happy to pay something peter
frednork Posted February 18, 2023 Posted February 18, 2023 Just checked and the remote I saw there was not matching unfortunately, The tv is an older model so may not have suited anyway. According to the neighbour when last used it had an intermittent fault so not sure if useful for parts but here's the model just in case.
Ollie0967 Posted February 18, 2023 Posted February 18, 2023 Hey mate I have a spare Pioneer remote lying around at home. I’ll check after i finish work this afternoon. If it suits your needs you can have it… Where are you located?
SonicArt Posted February 19, 2023 Posted February 19, 2023 Had good success with generics and clones over the years, just picked up an Arcam CD built around 89', picked up an Arcam clone remote for 18 bucks from Ali, works perfectly, even the repeat button (which the machine doesnt have and it has a lot of buttons!) works, nothing happens visually when you press it, but the machine repeats!
