Rivendell Posted February 27, 2023 Posted February 27, 2023 SOTM sMS-200ultra Neo + sPS-500 DC External Power Supply I am selling 2 items together, the streamer and the identical looking complimenting external DC power supply This model (sMS-200ultra Neo) is the current selling premium version Ultra Neo (not to be confused with the previous models, the original SMS 200, the SMS Neo or the previous model the SMS 200Ultra) My price INCLUDES Australia EXPRESS Post shipping costs to any place in Australia. I purchase in December 2021, so just 14 months ago from an Australia HIFI retailer. Both units have their original SOTM boxes. I can also supply the purchaser with my original invoice if required. I am Selling them “as new” in Mint condition both together for 1/2 their current RRP. RRP for sMS-200ultra Neo is $1,900, RRP for sPS-500 DC External Power Supply is $800 My sell price both together is $1,350 My thoughts on WHY this Network Music Player and Premium DC Power supply, is such an incredible and acclaimed digital source… Market leading (when DC Powered with the sPS-500), extremely low Noise & low Jitter streaming source. Best in class under $4,000 IMO… It’s the Perfect HQPlayer NAA/endpoint allowing HQplayer Desktop to run elsewhere I use it as an Ultra low Jitter low noise Roon end point, feeding via the renowned SOTM Audio grade USB, my Holo May KTE DAC. It’s a highly optimised Roon endpoint. Simple switching (5 seconds or so…) from a Roon end point to Shairport’s Airplay 2 support, feeds my Apple Music streams seamlessly to the DAC It can stream up to PCM 32bit/768kHz max, DSDx512 max. These are very high max rates compared to most streamers. The super high quality of the internal sCLK-EX clock here’s a great Video Review by Hans Beekhuyzen here: https://www.youtube.com/watch?v=uADNLgJ3tSA&t=56s Further info/specs from the Maufacturer… Description The sMS-200ultra Neo is a compact designed high performance network file player which is capable to share and play music file through network system. You can simply set up the multi-room network audio system by connecting a USB audio device to the ultra high quality USB audio port on the rear panel of sMS-200ultra. Key features • Optimised HiFi Eunhasu Linux OS • Roon Ready • SqueezeLite • DLNA Renderer • MPD • Logitech Media Server • HQ Player NAA (Network Audio Adapter) • Shairport (supports Airplay 2) Audio feature PCM 32bit/768kHz max, DSDx512 max Ultra Low Noise Regulator Active Noise canceller USB port High-End audio grade USB port x 1 USB 2.0 port x 2 Ethernet port RJ45 Gigabit Ethernet External power input Input voltage : 9Vdc(Optional 12.0Vdc or Optional 6.5~8.5Vdc) Input current : 2A max 5.5mm OD, 2.1mm ID adaptor jack Internal reference clock sCLK-EX2425 board External master clock input : Optional Input frequency : 10MHz Isolated clock input 50Ω SMB connector x 1 Dimension 106 x 48 x 227(mm) Weight 1.5kg ALSO INCLUDED sPS-500 DC power supply for high end audio devices. Description The sPS-500 is an audio power supply designed specifically for high performance audio. It is built to eliminate noise generated by powered devices as well as to remove noise coming from an AC power source. Using SOtM’s unique technologies for noise cancellation and sound enhancement, and high quality audio components that are already proven in sound quality, you will hear superior sound with the well-designed sPS-500. The sPS-500 can easily cope with a wide range of AC power input – the output voltage can change to 7Vdc, 9Vdc, 12Vdc or 19Vdc depending on the power specification of your audio equipment – and the 50W output is flexible enough to be applied to various audio systems. It is also designed to provide more stable power through the input, output, overcurrent and overheat protection circuits. Key Features 7Vdc, 9Vdc, 12Vdc, 19Vdc selectable output voltage Eliminate noise generated by powered devices 50W output power for NAS, fanless audio PCs and others Support worldwide AC input voltage Output short, over temperature protection User interface DC output on/off switch Operating indicator LED x1 AC power input on/off switch(Rear panel) AC power input Voltage : 100Vac ~240Vac Frequency : 50Hz / 60Hz Current : 2.5A > DC power output Voltage : 7Vdc, 9Vdc, 12Vdc, 19Vdc selectable Voltage tolerance: ±10% Current limit: 5A@ 7Vdc, 9Vdc, 12Vdc 3.3A@ 19Vdc Current tolerance: ±10% Maximum output power : 50W@100Vac <, +50℃ > inside temperature Protection Output short Over temperature Dimension 106 x 48 x 230(mm) Weight 2Kg NOTE requires a standard C15 AC power cord (not included) GoldenOne mini review here: https://forum.hifiguides.com/t/streamer-ddc-showdown-pi2aes-vs-sotm-sms200-ultra-neo/15025
Grizaudio Posted February 28, 2023 Posted February 28, 2023 @MrBurns84 you could possibly mod with clock input. 1
