Emubitter Posted March 12, 2023 Posted March 12, 2023 Further Information: I built these speakers with the help of a friend about two years ago. The design is reasonably well known, you can read up on it at TG's website. For clarity I purchased the top specification crossover components and Be tweeters and have docs to authenticate. The cabinets are finished in Jarrah veneer with Danish Oil treatment. Great full spectrum output, you won't need a sub with these 15 inchers in play, bass is deep, tuneful and lots of it.. The Satori Be tweeters sing sweetly and have never seemed fatiguing to me. Of reasonable sensitivity I think around 30W is quoted as the low end for amplification, at times I have ran perfectly happily on my 18W valve amp. Bi amping is also an option with four binding posts per speaker. The low rise stands can go with the speakers, I found the bass improved just getting that little bit off the floor. Hit me up for further info, I guarantee audition will impress. These were keepers until I was lucky enough to upgrade to speakers I have dreamed of owning for a very long time. I took this ad down after two days in a premature fit of seller's remorse but with the newcomers settling in, these have to go! 2 1
