MattyW Posted April 14, 2023 Posted April 14, 2023 (edited) On 11/4/2023 at 4:53 PM, andyr said: Agreed. I'm afraid I don't quite agree with you there, Ray ("any amp with any spkr")! Try driving a pair of 3-way Maggies with a SET and I suggest you will blow the true-ribbon - even at a low volume level ... because the SET will be clipping. Or single driver full range speakers with a high power class ab or d amp. Sounds like absolute shite! Depending on efficiency generally far happier with fleawatt to 50WPC class A solid state, or various tube amps (single ended, push pull, OTL etc). I guess there might be an exemption to this generalisation though not in my personal experience. Heck with my current 98db @ 1W/1M sensitive speakers I struggle to play quietly enough with my 15WPC power amp but damn doesn’t it sound glorious! May be a bit more of a challenge when my new 103db @ 1W/M speakers arrive next weekend though I’m sure I’ll figure it out somehow Edited April 14, 2023 by MattyW 1
tripitaka Posted April 15, 2023 Posted April 15, 2023 21 hours ago, MattyW said: Or single driver full range speakers with a high power class ab or d amp. Sounds like absolute shite! Depending on efficiency generally far happier with fleawatt to 50WPC class A solid state, or various tube amps (single ended, push pull, OTL etc). I guess there might be an exemption to this generalisation though not in my personal experience. Heck with my current 98db @ 1W/1M sensitive speakers I struggle to play quietly enough with my 15WPC power amp but damn doesn’t it sound glorious! May be a bit more of a challenge when my new 103db @ 1W/M speakers arrive next weekend though I’m sure I’ll figure it out somehow Matty I'm a fan of your work, no doubt, but just want to check what you are saying here. You like low power amps, fair enough, but is this directed particularly towards use with full range drivers (which very few people run), or is it more a general diagnosis? Like most folks, I guess(?) I run 90dB-ish multi-driver speakers, and I have to say that I prefer 500+W per channel to get the best out of them. Have we taken a wrong turn here?
MattyW Posted April 15, 2023 Posted April 15, 2023 (edited) 2 hours ago, tripitaka said: Matty I'm a fan of your work, no doubt, but just want to check what you are saying here. You like low power amps, fair enough, but is this directed particularly towards use with full range drivers (which very few people run), or is it more a general diagnosis? Like most folks, I guess(?) I run 90dB-ish multi-driver speakers, and I have to say that I prefer 500+W per channel to get the best out of them. Have we taken a wrong turn here? No, I was merely saying that the "any amp with any spkr" generalisation was a poor one. Enough power to control a driver well is only part of the equation. There is certainly such thing as too much power though I’m not aware of whether it’s actually too much power or just exposing the shortcomings of class AB or D power amps. That was specific to full range driver based speakers though I myself generalised Edited April 15, 2023 by MattyW 1
Volunteer sir sanders zingmore Posted April 15, 2023 Volunteer Posted April 15, 2023 21 hours ago, MattyW said: Heck with my current 98db @ 1W/1M sensitive speakers I struggle to play quietly enough with my 15WPC power amp I suspect that's a question of gain rather than power. I've happily run higher sensitivity speakers with significantly higher powered amps 2
ray4410 Posted April 15, 2023 Posted April 15, 2023 8 minutes ago, MattyW said: No, was merely saying that the "any amp with any spkr" generalisation was a poor one. Enough power to control a driver well is only part of the equation. There is certainly such thing as too much power though In not aware of whether it’s actually too much power or just exposing the shortcomings of class AB or D power amps. That was specific to full range driver based speakers though I myself generalised any amp with any speaker AS LONG AS YOU KNOW BOTH THEIR LIMITATIONS 5
andyr Posted April 15, 2023 Posted April 15, 2023 44 minutes ago, Mendes said: Synergy, synergy, synergy...... aka ... "2 + 2 = 5"? 1
Mendes Posted April 15, 2023 Posted April 15, 2023 31 minutes ago, andyr said: aka ... "2 + 2 = 5"? 100% Andy
LogicprObe Posted April 15, 2023 Posted April 15, 2023 2 hours ago, ray4410 said: any amp with any speaker AS LONG AS YOU KNOW BOTH THEIR LIMITATIONS Never fear! They'll be back asking why their 'XYZ' blew up anyway! 1 1
Mick64 Posted April 16, 2023 Author Posted April 16, 2023 So i hooked up the new crown amp - a display model that was in absolute brand new perfection condition. And WOW ! The improvement ..... the bass !!! I could start to feel the walls vibrating with the improvement in power. It sounded more crisp, and less bright. I haven't even done the YPAO tests - but the upgrade from crown xli1500 to xli 2500 was without doubt the biggest change in my audio system ever ! I tested the song Vanilla Ice - Ninja rap and i could literally start to feel pure, club like bass that i had slighty before, but now had so much more of. Ah man And with ebay discount, and the fact it was a display B grade stock, only paid $720 for it.... 3
