Nic H Posted May 3, 2023 Posted May 3, 2023 (edited) REL t9i subwoofer In 9/10 condition Works perfectly Pick up or view in Rye smoke free home REL’s T/9i is an excellent subwoofer for the audiophile. It’s capable of making big bass noises, but is also more than capable of freeing up the loudspeakers and liberating them from the dictatorship of the room. While there is no substitute for huge bass traps and other room treatments, a pair of T/9i get you most of the way there without the domestic angst room treatment can cause. Highly recommended. * Type: active subwoofer * Inputs: Hi Level Neutrik Speakon, Low level single LFE phono * Output: low level single LFE phono * Drivers: 1× 254mm long-throw woofer with inverted dust cap, 1× 254mm passive radiator * Power output: 300W (RMS), Class AB * Controls: High and low level controls, crossover frequency cut-off, 0°/180° phase switch * Dimensions (H×W×D): 387×330×407mm * Weight: 18.7kg Edited May 3, 2023 by Nic H More pics 2
