Class A Audio Posted May 26, 2023 Posted May 26, 2023 Further Information: Location: Class A Audio, 8/585 Blackburn Rd, Notting Hill, VIC, 3168. phone (03) 8555 0735 A bridgeable power amplifier that delivers stunning dynamic realism and expressive refinement. Housed in a chassis milled from a solid block of aircraft-grade aluminum, the Model 525 features an innovative topology that epitomizes power and efficiency. From a single Model 525 in stereo mode at the core of an intimate audio system, up to multiple bridged units powering a complex home theater setup, down to a bridged pair driving a sophisticated two-channel environment, the Model 525 delivers exquisite resolution, authority, and control to speakers of almost any size and any load. Specifications Output Power (Stereo) 250 watts @ 8 ohms / 500 watts @ 4 ohms Output Power (Bridge-tied Load) 950 watts @ 8 ohms BTL Frequency Response 5 Hz – 70 kHz, -3dB Input Impedance 40k ohms THD + Noise < 0.05%, 20 Hz - 20kHz Damping Factor > 1000, @ 1kHz Overall Gain 26/32 dB BTL Amplifier Weight 14.5 lbs. / 6.6 kg Overall Amplifier Dimensions (h/w/d) 2.85” x 8.4” x 13” / 72mm x 213mm x 330mm 1
