Class A Audio Posted May 26, 2023 Posted May 26, 2023 Further Information: Location: Class A Audio, 8/585 Blackburn Rd, Notting Hill, VIC, 3168. phone (03) 8555 0735 The Model 125 stereo bridgeable power amplifier delivers dynamic realism and refinement from its solid aircraft-grade aluminum chassis, a perfect match for the sleek profile of its companion Capri S2 preamplifier. From a single M125 in stereo mode powering an intimate analog system, up to several bridged units driving a multi-speaker setup, down to a bridged pair controlling demanding 4-Ohm monitors, the energy-efficient Model 125 power amplifier delivers consistent resolution and authority with Rowland finesse. Specifications Output Power (Stereo) 125 watts @ 8 ohms / 250 watts @ 4 ohms Output Power (Bridge-tied Load) 500 watts @ 8 ohms BTL Frequency Response 5 Hz – 130 kHz, -3dB Input Impedance 40k ohms THD + Noise < 0.008% @ 1kHz Damping Factor > 500, @ 1kHz Overall Gain 26 Amplifier Weight 7.8 lbs. / 3.5 kg Overall Amplifier Dimensions (h/w/d) 2.7” x 13.7” x 7.5” / 68mm x 348mm x 190mm 1
