Icon Ps1.2 mm/mc phono pre amp
Purchased 2 months ago from Groove audio in Melbourne.
In perfect working order,
Original packaging
Warranty
Current model
Rrp $3100
Original power cables (not mine)
Going a different direction, very happy with the sound.
Pick up or view in Rye 3941
Will post at buyers expense auspost.
Specifications and Features
• Built in volume control, will drive most power amps
• Stereo/mono switch for better S/N and distortion from mono and worn stereo records
• Choke regulated power supply
• Separate Power supply for lower noise
• Comprehensive manual supplied
• All hand wired point to point
• No printed circuit board to ‘colour’ sound
• Japanese Blue ALPS volume pot.
• All Triode valves
• 2x ECC83 1x ECC81
• Sensitivity: 3mv for 1.26v output (0.3mv MC)
• Gain MM 53db MC 72db
• Load: imp: 47k MM, 100 ohms MC
• Source impedance 50 ohms
• Signal to noise level -75db (MM unweighted)
• RIAA Freq response 20hz-20khz 0 – 1db
• NO feedback used, Passive RIAA
• High quality 2w metal film, & wire-wound resistors
• Blue LED mains indicator
• Polypropylene audio capacitors
• Silver PTFE audio cable
• DC supply for valve heaters
• Heater circuit floated to minimise heater-cathode noise
• Polished stainless steel chassis
• 6mm solid alloy front & rear plates
• Gold plated Input terminals
• 230/240volts (also 120v), 50watts 1.0A anti-surge fuse
• Dimensions
88mmW, 310mmD (350), 134mmH , 3kg Pre-amp
(figures in brackets allow for rear connections)
165mmD, 82mmW 80mmH 4kg PSU
• Shipping size/weight 42cm x 38cm x 30cm 9.6kg
• C E certified. Conforms to ROHS and WEEE
Edited by Nic H
