I have barely used this amplifier!
It was bought for a project that did not go ahead.20230627_170957.thumb.jpg.5f7c58e310c0e1f9fd6f3f8ba1b4da04.jpg20230627_171047.thumb.jpg.899c6571de1cfb9fe3f09d317b3d175a.jpg
Specifications:
Power per Channel (Watts RMS)
7 Channel at 8 ohms 190
7 Channel at 6 ohms 225
Dynamic Power (Watts RMS)
8 Ohms 200
4 Ohms 400
Total Harmonic Distortion THD  @1Khz < 0.0003%
THD  <0.001% 20-20Khz
Frequency Response 3Hz - 250 kHz. +0,-3 dB
S/N Ratio 111 dB
Input types: Balanced & RCA
Single Potted Silent Power Transformer Yes
Discrete Power Amplifier Circuitry Yes
Banana Plug Compatible Speaker Connectors Yes
12V Trigger Yes
Height 160 mm Width: 445 mm Depth: 370 mm
Weight 25 kg
Pickup from Mernda VIC 3754 only.
When you consider this is priced at $300 per channel it's amazing value.
I use my HD2 for 2ch also and when you consider that the 2 channels cost only $600 it's madness. Mine replaced a 2ch Rotel 200w per channel amp that cost twice as much secondhand and I haven't missed it at all.
  • Love 1
Is this still for sale?
if so $2000 cash pick up tomorrow Sunday need reply today to withdraw cash
