Marvin55 Posted July 29, 2023 Posted July 29, 2023 (edited) Champagne in Colour Complete with remote and stabilizer, excellent condition. Specification Type CD Transport Wow and flutter Unmeasureable Digital Output: Single Ended: 2 Vrms S/PDIF (RCA) Balanced : 4 Vrms AES/EBU (XLR) Power supply voltage 240 VAC, 50Hz/60Hz Power consumption 14W External dimensions Width 435x Height 100x Depth 290 mm Weight 9.3 kg Attachments: Stabilizer Wireless Remote Control (RU200) Power cord Edited July 29, 2023 by marvin55 Errors in spec pointed out to me. 3
rockeater Posted July 29, 2023 Posted July 29, 2023 13 hours ago, marvin55 said: Frequency characteristic 2 Hz to 20 kHz ± 0.5 dB Signal-to-noise ratio 110 dB or more I was so intrigued by having frequency response and signal to noise ratio specified for a transport, that I looked up a service manual for this unit and have found that they are not listed. This unit cannot have these, because it does not have a DAC. The specs are: 1
Marvin55 Posted July 29, 2023 Author Posted July 29, 2023 You are correct. I posted the specs in a bit of a rush and I believe they relate to the redbook standard rather than this transport. Mea culpa. I have removed the offending specs but here they are, and yes in hindsight they are silly. "Frequency characteristic 2 Hz to 20 kHz ± 0.5 dB Signal-to-noise ratio 110 dB or more" cheers Tony 1
RockRolley Posted July 31, 2023 Posted July 31, 2023 I’ve had one of these paired with my ABBAS Dac. So musical. I’ve felt no need to upgrade. I liked it so much I snapped up another recently for my second system. When I picked it up I couldn’t park at the person’s residence and had to lug it a block away-weighs a ton!! GLWTS
