missmurphy Posted August 18, 2023 Posted August 18, 2023 (edited) This was fitted to a linn that had a tonearm wire problem, the micro arm had a terminal head shell issue, I ended up buying the rig and parting it out the cart has seen under 5 hours, as the original buyer took it home and had an intermittent contact problem , I fitted the cart and set up the arm, all correctly done! the stylus guard is missing, he apparently lost it this is a fantastic mm cart with top of the line shibata diamond I use moving coil and Deccas so this has to go Edited August 18, 2023 by missmurphy
