Further Information
Exemplar Audio 2A3/45 switchable SET powr amps built by John Tucker. Running 2A3 tubes now, can be simply swapped out for 45 tubes instantly.
Beautiful Macassar ebony enclosed chassis's.
power tubes: 2 x vintage RCA USN CFC 2A3 (tested at 85% and 91% with Roe Test)
driver tubes: 2 x Russian 6H1N-EB (tested at 100% with Roe Test)
Power tubes are direct coupled with no capacitors in the signal path. Film capacitors in the circuit are a power supply decoupling cap for a series regulator to reduce ripple and therefore noise..
power output is 3.5W before clipping into 8 Ohm.
input sensitivity to full output 1.2V RMS.
input sensitivity 250K Ohm.
quality components used in the build including Magnaquest Cobalt output transformer, V cap and Mundorf caps used.
Amps and tubes have been checked to be in very sound condition and ready for a new appreciative owner. Amps have that single ended purity and sound very well balanced and musical.
This a very affordable way to taste some single ended 2A3 or 45 tube magic for owners of efficient speakers.
Edited by aertex
more info added
  • Like 6
  • Love 2
I used to own the matching Macassar ebony Slagle Autoformer pre (the better Slagle with the flying leads).
The Macassar is real solid Macassar not a veneer and looked beautiful in the flesh.
These will be great amps.
LPG
I had the pleasure to listen to them hooked up to efficient full range speaker and I was blown away by how musical they are.
Firm lows and just beautiful mid range.
They would not disappoint that is for sure.
On 27/08/2023 at 9:39 PM, tuyen said:
Tempting!
Alan is coming to Perth soon , get him to bring em up for a demo Tuyen.
