Further Information: Im only selling this JBL soundbar and sub woofer as space is at a premium in my home, and I purchased a newer Bose soundbar with a smaller subwoofer.
If space wasn't an issue, I would never have bought the Bose, as the sound through the JBL system is really quite shockingly good, and beats the much newer Bose system hands down.
Size of soundbar is 116cm wide x 7cm deep
Subwoofer is 37cm x 37cm wide/deep and approx 47cm tall
If you're looking at new soundbar/sub to attach to your TV, stop and consider this setup as you won't find better unless you start looking upwards of $2000 new. I know - I auditioned quite a few systems. Can be connected via normal audio RCA jacks or optical digital cable. Hs adjustable EQ to customise the sound depending on whether or not the soundbar is up against the wall. Also comes with a remote.
There is a small issue with the sub woofer - one corner has been knocked, and the laminate is damaged, and the foot in that corner is slightly loose. Its not peeling away as such, and it's not really noticeable unless you go looking for it. Doesn't affect the terrific sound quality. See last pic. But as can be seen from the image of the underside the bass driver is untouched and looks like new, operates perfectly.
Pickup only as I don't have packaging.
