coffee25 Posted October 17, 2023 Posted October 17, 2023 (edited) Further Information: Selling my near new DAC in order to upgrade and get into DAC+masterclock path. Purchased from AddictedtoAudio on 11/07/2023. Weekend listener. Description Flagship Performance, Powerful, Stable The D70 Pro SABRE adopts the ES9039SPRO, the flagship 32-bit DAC chip of SABRE redesigned by ESS company. Brand New I/V Conversion New I/V conversion circuitry is designed to give you higher quality audio playback. Our circuitry uses an exclusive design that provides lower distortion and noise while occupying a smaller volume. We strive to demonstrate the full performance of our DAC chips to bring you a more superior audio experience. Aurora UI, Bring A New Experience Full color screen and three touch buttons, a changed experience. The display of playback information, FFT and VU meters can be switched according to your requirements. Bluetooth 5.1 Transmission The D70 Pro SABRE supports LDAC / aptX-Adaptive, aptX HD, aptX, AAC and SBC audio encoding, allowing higher quality audio to be transmitted wirelessly for a better sound experience. Freely Switch Output Modes The D70 Pro SABRE features the versatile RCA single-ended output and the professional XLR balanced output. You can turn on only the desired output channel, or both outputs at the same time. Integrated Preamp Function In addition to the fixed output level DAC mode, the D70 Pro SABRE also has a preamp mode. In this mode, the D70 Pro SABRE can adjust the volume and output directly to the power amplifier or active speakers. Edited October 17, 2023 by coffee25 correction
