Further information:
*Very good condition.
*No box.
*No scratches or dents.
*Comes with a set an additional high grade tubes.
The Audio Note (UK) Neiro Mono Power Amplifiers are Pure Class A Parallel Singled Ended valve amplifiers that use a pair of the highly regarded 2A3 triode valves per channel, producing a level of performance that is radically superior to the vast majority of current designs.
They have been specifically engineered for sonic performance rather than technical specification, and fulfil all Audio Note (UK) Level 4 criteria:
- Pure Class A operation Zero Negative Feedback
-Single Ended Output
-Stage Valve Rectification Directly Heated Triode operation
-Materials and component quality
-Each amplifier is completely hand assembled, and uses only the finest possible materials and components: - Audio Note (UK) customer Output Transformers, using AN(UK) Copper primary windings, AN(UK) Silver secondary windings and AN(UK) UHiB double C cores Audio Note (UK) custom 1 Watt Tantalum resistors Audio Note (UK) Copper Foil capacitors Audio Note (UK) Silver internal wiring Black Gate capacitors in critical areas
INPUT IMPEDANCE: 100KOhm
INPUT SENSITIVITY: 250mV for full output
MAXIMUM OUTPUT: 8 Watts RMS per channel into 4 or 8 Ohm loads
CHANNEL BALANCE: +/- 0.3dB
VALVE COMPLEMENT: 2 x 5U4GB (1 per chassis) 4 x 2A3 (2 per chassis) 2 x 6SN7 (1 per chassis)
UNIT WEIGHT: 10kg (per amplifier)
UNIT DIMENSIONS: 195mm (h) x 205mm (w) x 500mm (d) (per amplifier)
MAINS INPUT: 220 - 240V 50/60Hz MAX.
POWER CONSUMPTION: 200 Watts
All Pre-Owned items have been tested before listing. • NO WARRANTY. • We encourage buyers to test and verify the equipment condition at our showroom (1 Coleman Street, The Adelphi, Unit 03-35) — pre-owned condition as shown on our listed page.
Edited by hificomsg
