Further Information
This is an amazing CD transport for the money. The unit is in perfect working order and is immaculate. Selling as focussing on vinyl/streaming.
Top loading
  • Coaxial and optical outputs: 44.1 kHz SPDIF and AES/EBU, plus up-sampled 96 kHz and I2S output for DIYers.
  • Full Aluminum chassis made from CNC Machine cut
  • Sony KSS-213Q mechanism but very cleverly mounted and with even better digital signal processing implementation
  • Output 44.1kHz : Coxical x 1, Optical x 1, AES/EBU x 1
  • Output 96kHZ : Coxical x 1, Optical x 1, AES/EBU x 1
  • Frequency respond: 20Hz to 20kHz
  • THD <0.005%
  • S/N ratio >118dB
  • Dimension: 432mm(W) x 330mm(D) [not including jacks] x 900mm(H)
  • Weight: 8.5kg
  • INPUT VOLTAGE: AC240V/50Hz
I no longer have the box, so would prefer local sale. Can package and ship at buyer's expense/risk.
Edited by dafloro6601
Additional Info
Unit is about 3 years old but has seen very little action as I have a DCS Bartók and now stream most of my music - hence the sale.
Yes II bought it new so first owner.👍
