What do you have in your outdoor entertaining area?
Mine is super low cost....
Amp $100 inc postage, D!ck Smith 'monitors' $80, Tamons were free, Radio was a raffle prize. and the switch was $10
MP3 player was $129
post-109729-0-04465300-1388117324_thumb.
post-109729-0-89028700-1388117688_thumb.
post-109729-0-99975200-1388119660_thumb.
post-109729-0-53666100-1388123219_thumb.
post-109729-0-95278200-1388123264_thumb.
post-109729-0-08037900-1388123315_thumb.
No offence meant but I'd rather knock a hole in the room & put a large freekin sliding door in with fly screen, job done, crank er up!
Ran some cable from the NAD T787 to the alfresco, installed PSB CS1000.  I'm very happy with SQ as well as volume, plus can switch fronts on inside the home and have same music playing throughout.  $500 delivered.  Many could get away with the cheaper, smaller CS500 though.
Non taken
I had all this gear just doing nothing so used it for outside.
I'm thinking of an outdoor setup for new years Eve. My plan is to use my laptop communicating with my Synology NAS and use Audio Station.
For speakers I'm thinking of using some PC speakers from the headphone outlet on laptop.
probably would have done the same in circumstance. hows the Tivoli go?
I really like the Tivoli, great sound quality.
  • 4 years later...
Mine is reasonably low cost. Home made enclosure for TV and planter pallets. Old tablet to control spotify, plex and you tube via Chromecast and an Onkyo TX-8270 that also has google audio built in. Speakers Yamaha AW-592's would like to upgrade these.
Probably spend more time here than indoor system.
Pretty low cost, under $1000 and goes alright actually. Has the TV as a spare anyway. The Yammy streams everything and the speakers put out decent noise for bbqs and general background music etc. It's all connected to my inside foxtel via a hdmi splitter as well so it's great for Sunday arvo UFC or something whilst smoking my cigars. 1644ADBC-473B-4C08-884E-6C50989F687A.jpeg.49b021227aefed8402e7a825244e5234.jpeg6DADD450-C92B-4DAD-B440-49E7032146D7.jpeg.b10225bcadba38c269622377315eb58e.jpeg
  • 4 weeks later...
What speakers are you running there?
