gollux Posted December 10, 2023 Posted December 10, 2023 This is the top of the line cable from Forza Audioworks. I picked it up from another member for use on my Hifiman He1000 v2s, and I found that it was a major improvement over the stock cable in both sound and ergonomics - it's beautifully made, and the sound is effortless and organic. The cable is in great condition. It has a 6.3mm Furutech connector on one end and 3.5mm connectors on the other (for Hifiman, Focal, Sony, etc.). Price includes shipping. Reach out if you have any questions!
Neo Posted December 10, 2023 Posted December 10, 2023 Do you have the packaging and is the length 2m. Also it will fit Hifiman Ananda? Neo
gollux Posted December 10, 2023 Author Posted December 10, 2023 (edited) 33 minutes ago, Neo said: Do you have the packaging and is the length 2m. Also it will fit Hifiman Ananda? Neo Yep, I have the original packaging! I haven't used the Ananda, but it appears to use the same 3.5mm connectors as my He1000 v2s - so yes, it will fit. Edited December 10, 2023 by gollux
wasabijim Posted December 10, 2023 Posted December 10, 2023 do you know if the 6.3mm plug can be switched over to a balanced? really after this but 2.5 or 4.4mm. sometimes its an easy thing to do
gollux Posted December 10, 2023 Author Posted December 10, 2023 2 hours ago, wasabijim said: do you know if the 6.3mm plug can be switched over to a balanced? really after this but 2.5 or 4.4mm. sometimes its an easy thing to do I believe it's straightforward to reterminate most cables, but I've never done it myself. Perhaps someone else on here can advise? 1
