I purchased these from Scan Audio  back in the nineties when I was manufacturing speakers.
They are made from 20mm double veneer with lock mitre joints  and approximately 13 Liters in internal volume.
They have had a single coat of black undercoat.
Front panel cutouts:
Tweeter   74mm hole 94mm rebate
Woofer  145mm hole 172mm rebate
Weight 5.5Kgs each
Dimensions  336mm high,  218mm wide  &  285mm deep.
The cutouts were to suit older series Vifa  drivers however there is a current series SB Acoustics that fits perfectly.
http://www.theloudspeakerkit.com/sb17nrxc35-8-uc-sb-acoustics-6.5-mid-woofer-nrxc-u
Also the Satorie  series SB Acoustic 6" woofers fit as well
A Vifa D19 will fit the tweeter cut out & is available from Digikey Australia
https://www.digikey.com.au/en/products/detail/peerless-by-tymphany/D19TD05-08/6557405
They come with finished grills & sockets for the cabinet side.
The timber veneer is Jarra but they have been undercoated in black.
Also includes a nice flush mounted port & internal foam damping.
A set of gold banana post speaker terminals will be included that's fits into the rebate for a flush look.
I would prefer pickup only but I have the original shipping cartons so if you want to arrange a courier & take all responsibility that is fine.
These are a lovely quality made cabinet & at $75 a pair excellent value.
I have the original Electronics Australia article which describes a finished speaker using the Jaycar kit (same size cabinet) with a Vifa D19 tweeter and a Jaycar woofer - PM me and I can send it to you.
Please PM me if you require further information.
Update - I can arrange for courier delivery but as I explained before you will have to accept all responsibility.
eg if damaged your problem.
Edited by Gieseler Audio
More info
wow. these are nice. i think as good if not better than the other ones that were advertised before.
how much do you think delivery would cost? (to canberra).
cheers,
mal.
Yes definitely easier build than the Jaycar version as it includes finished grills & cabinet assembly is complete.
Also two more higher end tweeter options that will drop in
Scanspeak D2008
Hiquphon OW
OK shipping to Canberra.
Amerex  $36     3 - 5 business days
Couriers Please $38   2 - 3 business days.
Both include $100 insurance
