This is a well-built 5V / 2A linear power supply. I used it to power a Raspberry Pi 3B with digital audio HAT as part of my Roon setup. I've relocated the gear to a new location that doesn't suit the higher heat generated by a Linear PSU.
As you can see, there are two outputs on the front: USB-A and coaxial DC. I used the USB-A output.
Item works fine. All-metal housing with plenty of heat-sinking. Supplied with IEC mains cable but no DC cable.
Full details available from the (continuing) eBay listing. https://www.ebay.com.au/itm/264255536988
Can be bought new and shipped to Oz for AUD125 landed (by comparison).
PXL_20240109_033955810.thumb.jpg.7b3998cf45249be781530cb39dfa66f8.jpgPXL_20240109_033942973.thumb.jpg.fe9815a9dd5532e42f0e5133efea4e3b.jpgPXL_20240109_033930802.thumb.jpg.733efdadb27c21613a2175bf639ea160.jpg
