Martin Lamb Posted February 11, 2024 Posted February 11, 2024 Further Information: Classic Australian high fidelity speakers from the early 90s. This is an early iteration without the black plastic faceplate. A flagship speaker from one of Australia's most renowned speaker manufacturers of the era. Beautiful jarrah veneer, with a minor scratch on a single side of both speakers. Frequency response: 45Hz to 20 KHz +/-3dB Sensitivity: 88dB 1W/1M/8 OHMS .Impedance: 6 OHMS Nominal, 4 OHMS Minimum Weight: 18Kg each Dimensions: Height 960mm, Width 168mm, Depth 265mm 2
Wimbo Posted February 11, 2024 Posted February 11, 2024 Cant believe nobody bought these. Give them to somebody you love mate.
sdotmouse Posted February 11, 2024 Posted February 11, 2024 people are too busy pissing around with DSP to put a good conventional system together mouse 5
georgehifi Posted February 11, 2024 Posted February 11, 2024 7 hours ago, Wimbo said: Cant believe nobody bought these. Picture of all the drivers without the grills could help? Cheers George 5
POV Posted February 12, 2024 Posted February 12, 2024 19 hours ago, sdotmouse said: people are too busy pissing around with DSP to put a good conventional system together mouse What do they listen to their DSP enabled electronics on I wonder?
