Buzzy74 Posted February 15, 2024 Posted February 15, 2024 Hi guys, I have a questions for you’s. I have a Yamaha Rx-V6A amp with Dali concept 6 front tower speakers with a Krix mini centrix for the center speaker. My question is can I run tower speakers for my rear/surround instead of book shelf speakers? I have a spare pair of Krix towers lying around. All are 8 Ohm. Thanks.
The Rock Puppy Posted February 15, 2024 Posted February 15, 2024 Since you've got some spare speakers hanging around, it will cost you nothing just have a go and see what you reckon. 1
Guest Posted February 15, 2024 Posted February 15, 2024 Why not? If you want the best experience, use the same brand speakers. If that is not possible, then timbre match them (they all sound the same).
andyr Posted February 15, 2024 Posted February 15, 2024 1 hour ago, Buzzy74 said: Hi guys, I have a question for youse. I have a Yamaha Rx-V6A amp with Dali concept 6 front tower speakers with a Krix mini centrix for the center speaker. My question is can I run tower speakers for my rear/surround instead of book shelf speakers? Using your front spkrs as rears ... will cause their phase to be reversed!! 1 hour ago, Buzzy74 said: I have a spare pair of Krix towers lying around. All are 8 Ohm. Being serious now ... I would've thought it is a much better idea to have front spkrs (L, mid & R) from the same mfr - and use 'foreign' spkrs for the rears.
Buzzy74 Posted February 15, 2024 Author Posted February 15, 2024 Well now ive got Center - Krix centrix Front - Dali concept 6 towers Rears - Krix apex Mk 3.1 towers I’m sure the Yami amp should be ok with it.
vuman619 Posted February 29, 2024 Posted February 29, 2024 You sure can, I'm doing it with 4 x B&W DM604 for the Front and Rear L/R, is great for music. 1
