andyr Posted March 15, 2024 Author Posted March 15, 2024 (edited) 9 hours ago, Warren Jones said: My Technics documentation specifies the output as Zero to Peak Verrry interesting! 9 hours ago, Warren Jones said: The output of the CS-100 is 0.76mv/cm/sec so at 5cm/s the output is 3.8mV Vertical modulation. And bcoz the Analogue Productions Test LP is recorded at 7cm/s ... the cart output is 5.32mV, for my test. 9 hours ago, Warren Jones said: Assuming peak 3.8 X 0.707 = 2.69mVRMS X (40dB) 100 = 269mVRMS But if we use the 5.32mV peak figure - instead of your 3.8mV - we get 5.32 x 0.707 x 100 = 376mV RMS. I measured 365-370mV RMS ... which is very close! So in conclusion: the output specified for carts (or at least my and your Stanton WOS CS100 - and your Technics) ... is peak! (IE. sero to max amplitude.) and the nominal 100dB (100x) MM gain of my Hagerman phono stage is actually a bit less than this. Thanks everyone for your help in solving my initial question. Edited March 15, 2024 by andyr 1
aussievintage Posted March 15, 2024 Posted March 15, 2024 3 hours ago, andyr said: the output specified for carts (or at least my and your Stanton WOS CS100 - and your Technics) ... is peak! (IE. sero to max amplitude.) I had been trying to tell you that. It's the only thing that makes sense of a velocity based specification.
TS23 Posted March 15, 2024 Posted March 15, 2024 (edited) 13 hours ago, andyr said: Thanks everyone for your help in solving my initial question So, is the next logical question: "For a range of your favourite records, what is the variation in recorded peak velocities/output levels?" This might give us a clue as to headroom requirements for phono stages etc. Cheers B Edited March 15, 2024 by TS23
andyr Posted March 15, 2024 Author Posted March 15, 2024 10 hours ago, aussievintage said: I had been trying to tell you that. It's the only thing that makes sense of a velocity based specification. You had, av ... but I didn't believe you! Sorry - I should've. 33 minutes ago, TS23 said: "For a range of your favourite records, what is the variation in recorded peak velocities/output levels?" This might give us a clue as to headroom requirements for phono stages etc. Re. headroom ... given that the HFs are recorded onto the grooves with a 20dB (10x) boost for HFs (with a corresponding 20dB cut for LFs) and we need to allow another 10x for transients - there needs to be enough headroom to cope with 100x the nominal signal level produced by the cart.
TS23 Posted March 16, 2024 Posted March 16, 2024 3 hours ago, andyr said: You had, av ... but I didn't believe you! Sorry - I should've. Re. headroom ... given that the HFs are recorded onto the grooves with a 20dB (10x) boost for HFs (with a corresponding 20dB cut for LFs) and we need to allow another 10x for transients - there needs to be enough headroom to cope with 100x the nominal signal level produced by the cart. Agreed, but just thought it would be nice to measure a few favourite lp's, rather just a test signal, to see where the "industry standard" levels equate to "industry practice" recorded levels. Cheers B
