Mr_Gimlet Posted February 25, 2024 Posted February 25, 2024 Further Information: I've had this power amplifier driving my rear speakers for a few years, but I am replacing the speakers with actives and so the power amp is no longer required. I bought it from another SNA member but I can't remember much about it. I can probably drop most places in Melbourne but I don't think shipping will be economical - but happy to do at cost. I don't have the packaging. Can output 2 x 90WRMS/ 1 x 90WRMS and 2 x 45WRMS/ 4 x 45WRMS Specs: 2 CHANNEL MODE Power output into 8 ohms (20Hz~20KHz) ..............................................................90W With both channels driven Rated THD. .......................................................................................................0.03% 1KHz clipping power into 8 ohm ........................................................................100W Damping factor ....................................................................................................>100 Input sensitivity for 1W/90W into 8 ohm ................................................91mV/866mV Power output into 4 ohms (20Hz-20KHz) .......................................................... ..45W 4 CHANNEL MODE With all channels driven Rated THD. .......................................................................................................0.05% 1KHz clipping power into 4 ohm ..........................................................................50W Damping factor ....................................................................................................>100 Input sensitivity for 1W/45W into 4 ohms ............................................130mV/866mV Input impedance ................................................................................R=10K C=200pf Frequency response 20Hz~20KHz ................................................................+/-0.5dB "A" WTD. singal to noise ratio (ref. 1W/8 ohms) ...............................................100dB Dimensions (WxHxD) .......................................................................430x112x288mm Net weight ...........................................................................................................9.5kg Shipping weight ................................................................................................10.5kg Power consumption ............................................................................................360W
