Further Information
For sale is a Plum Audio DAB, DAB+ and FM Tuner. It comes with connection for external antenna: a wire antenna is supplied. It has a power adapter, remote control and manual. The tuner has RCA outputs for connection to an audio amplifier. A pair of RCA cables is included. All functions are controlled by the remote. Selling as I have recently upgraded. Have owned for a number of years  but it has had little use since purchase. I found the tuner easy to set up and use.
“The Plum Audio makes do without the Wi-Fi / Ethernet, digital audio playback (via USB), and Internet Radio. Instead, the box only does one thing – provide instant access to digital radio stations”. The unit is fairly small, measuring 150 x 70 x 60 mm. Connecting the tuner to a system is easy – simply install the antenna, connect the tuner to an available RCA port, and plug it in. The unit automatically turns on and scans for all available DAB+ stations. The remote controls everything from rescanning the digital stations (Auto+) to switching between DAB+ and FM. Users can also store up to nine of their favourite digital radio stations, change stations (using the Tun+ or Tun- buttons), and adjust the information display.
The unit shows the station name and one of the following – Song title and album information; Program type; Signal strength; Time and date; Program Type; and Transfer rate”.
  • Love 2
