Further Information:
Location: Class A Audio, 8/585 Blackburn Rd, Notting Hill, VIC, 3168. phone (03) 8555 0735
The F1-8 loudspeaker distils the same technology and expertise utilised in its floorstanding siblings, into a smaller standmount format. The hand crafted cabinet is supported on a machined aluminium plinth that houses Fyne’s state of the art BassTrax LF diffuser. Surrounded by FyneFlute rubber surround, the F1-8 features a 200mm IsoFlare low frequency driver mated to a 25mm magnesium dome compression tweeter to create a point source, time aligned transducer delivering pure isotropic radiation across the entire audio spectrum. Hand finished at Fyne Audio’s UK manufacturing facility in stunning real walnut veneer with burr walnut inlay, the F1-8 represents the pinnacle of Hi-Fi UK loudspeaker design in standmount speaker format.
Specifications
System Type 2 way, downwards firing port, with BassTrax Tractrix diffuser
Recommended amplifier power (Watt RMS) 30 - 180
Peak power handling (Watt) 360
Continuous power handling (Watt RMS) 90
Sensitivity (2.83 Volt @ 1m) 91dB
Nominal impedance 8 Ohm
Frequency response (-6dB typical in room) 33Hz - 34kHz
Drive unit complement 1 x 200mm IsoFlare point source driver, multi-fibre bass / midrange cone, FyneFlute surround with 25mm magnesium dome compression tweeter, ferrite magnet system
Crossover frequency 1.8kHz
Crossover type Bi-wired passive low loss, 2nd order low pass, 1st order high pass. Deep Cryogenically Treated
System adjustments Presence (2.5kHz - 5.0kHz) +/- 3dB
Dimensions - HxWxD 470 x 280 x 441mm (18.5 x 11.0 x 17.4”)
Net Weight - Each 15.2kg (33.5lbs)
Finishes Piano Gloss Walnut
