Further Information:  I bought this on SNA over 12 months ago, with a wish to hear the legendary PCM1704UK Chips in action.  I enjoyed the sound and the music it makes  but it doesn't quite suit my system as I prefer balanced and a DAC with volume control.
Yes, it does have balanced outputs but the gain is not sufficient for my system.  Also, it requires a warm up period of 30 to 60 minutes.  As I don't normally leave equipment on when not using I was not always able to enjoy the music when I was intending.  As such, I am getting a different DAC to suit my needs.
The list of features in the design of this DAC is extensive so please follow the link.  The DAC comes with standard power cord.  I have the original box so can ship interstate but would definitely prefer pickup.
http://www.audio-gd.com/Pro/dac/RE7/RE7EN.htm
And a review of the Ref 7.1  (NB. Ref 7 has preferred setting rather than being changed)  https://darko.audio/2011/04/audio-gd-reference-71-dac-8-x-pcm1704uk/
DAC  Reference 7 Specs
RCA Output
S/N Ratio:>118db
Output Level:2.5V
Frequency Breadth:20-20KHz
Hi Antripodean
What happen if you turn it on and start music straight away , do you hear anything ?
Thanks for your time .
Regards
Hi Antripodean
Thanks for answer , just curious to see the warm up time , Wish you good luck with your sale .
Regards
