POV Posted April 11, 2024 Posted April 11, 2024 (edited) G'day, My son has purchased a JDS Labs DAC (EL DAC II+ Balanced) which looks to have dual 6.3mm connections for balanced outputs (at least that's what I think they are) and want's to use balanced connection to his headphone amp (iFi Zen Can signature) which has 4.4mm Pentacon balanced input. I've hunted the web and apart from cheap offerings on amazon etc can't seem to find any quality options. Anyone point me to a decent quality cable that will run between these 2 devices or do i need to have one made? Cheers. Edited April 11, 2024 by POV
SonicArt Posted April 11, 2024 Posted April 11, 2024 If you want a good quality cable likely have to be made for you, I have done these types of cable before using my Silver Line series interconnect, easy enough to get the 4.4mm plug, there are quite good ones available now with decent sized openings, the 6.3 is common enough. if you are interested shoot me a PM to discuss. 2
