Further Information:  Today we invite you to indulge in pristine sound with our immaculately maintained Krell KRC-2 Pre-amplifier and KSA-150 Power Amplifier duo, now available exclusively at Len Wallis Audio. This dynamic pair guarantees a symphony of clarity and power, delivering an unparalleled listening experience.
KRC-2 Preamplifier Features:
> Balanced line amplifier section for superior Signal-to-Noise ratio
> FET input stage to preserve sound quality amidst impedance variations.
> Bipolar output stage for robust, low-impedance configuration
> Full complimentary service in pure class A operation for optimal performance
Specifications:
Gain: 6dB or 2dB
Signal-to-Noise: < -95 dB unweighted
THD: 1K < 0.02%, 20K < 0.02%
Input Impedance: 47,000 ohms (47K)
Output Impedance: 10 ohms
Output Voltage: 16 volts R.M.S.
KSA-150 Power Amplifier Highlights:
> High power, class-A amplifier for an immersive audio experience
> Dual Left and Right outputs for bi-wire speakers
> 300W per channel into 4 ohm speakers for robust performance
> Massive power supplies ensuring stability even down to 1Ω impedances
Specifications:
Power: 150W per channel into 8 ohms / 300W per channel into 4 ohms / 600W per channel into 2 ohms / 1,200W per channel into 1 ohm
Signal to Noise Ratio: 120 dB “A” Weighted
THD & IM Distortion: Less than 0.1% under all conditions
Slew Rate: In excess of 100 volts/microsecond
Input Sensitivity: 1.8V
Input Impedance: 47,000 ohms non-inverting & inverting inputs
Damping Factor: Greater than 500 from 20Hz to 20kHz
Power Consumption: 7 amps
Upgrade your audio setup today with this premium offering! Available now for $5,500 the pair + Freight to your location.
  • Love 3
Hi
Does the preamp have its remote?
I might be interested in the preamp if someone only wants the amp.
Understand you’d rather sell as a pair though.
Hi - we don't have the remote for this unit. We did initially consider splitting the two units and had put a price of $2,500 on the pre-amp. Still happy to do so if you would like to purchase it. Regards, Len
