McIntosh MC462 Power Amplifier In Excellent Condition.
Sadly I’m starting to sell off my HI-FI equipment. Down sizing and won’t have room for such mighty equipment.
In excellent condition, have original box with bottom mounting board for safe transport and manual. Still might be under warranty with McIntosh.
I had this paired with the c52 McIntosh pre amp and Sonus Faber Olympia III’s.
Please note amplifier , pre amp and speakers only set up in unit and room for photos. They were never powered up. They were used in my HIFI room. This is the kids tv room.
450 Watts x 2 Channels
66% increase in Dynamic Headroom compared to previous model
Quad Balanced Design with McIntosh Autoformers
ELECTRONIC SPECIFICATIONS
Power Output per Channel
450 Watts @ 2, 4 or 8 Ohms
Number of Channels
2
Total Harmonic Distortion
0.005%
S/N below rated output
122dB
Dynamic Headroom
3.0dB
Damping Factor
>40 Wideband
Rated Power Band
20Hz to 20kHz
Frequency Response
+0, -0.25dB from 20Hz to 20,000Hz
+0, -3.0dB from 10Hz to 100,000Hz
Unit Dimensions (W x H x D)
17-1/2" (44.45cm) x 9-7/16" (23.97cm) (including feet) x 22-1/2" (57.2cm) (including front panel, handles and cables)
Unit Weight
115 lbs (52.3 kg)
Shipping Weight
148 lbs (67.3 kg)
https://www.stereophile.com/content/mcintosh-laboratory-mc462-power-amplifier
The C53/MC462 combo sounded "super-smooth and superbly balanced at all times, whilst never letting the smoothness of their delivery interfere with their ability to resolve a level of detail, [which] means you will hear nuances you just will not hear with lesser amplifiers." - Audio Esoterica
The new generation MC462 stereo amplifier has received numerous updates compared to the previous model. The most prominent is that filter capacity has been increased by nearly 50%, which has resulted in a remarkable 66% increase in dynamic headroom from 1.8dB to 3.0dB. This allows the MC462 to easily handle drastic swings in dynamics and effortlessly reproduce your favorite music with virtually no distortion. Bass performance is also improved as a result of the filter capacity increase. Our eco-friendly power management system, which will turn the amplifier off after a set amount of time when no input signal has been detected, has been added. Internal wiring and select circuit components have also been upgraded.
Aesthetically, the MC462 retains all the hallmarks of a McIntosh amplifier with a few key modern enhancements. The front panel now utilizes direct LED backlighting that improves appearance and color accuracy. The two audio Autoformers and single power transformer are housed in new enclosures topped by a single machined cover with glass inserts. The back half of the amplifier is home to four of our Monogrammed Heatsinks™ which connect to advanced high current output transistors that help eliminate thermal equilibrium lag time.
The MC462 Amplifier and C53 Preamplifier named 2021 "Stereo Pre-Power Amplifiers of the Year Over AU$20,000." - Sound+Image
Besides these updates, the MC462 is packed full of other exclusive McIntosh technologies to bring your music to life:
Power Guard® that monitors and adjusts the input signal at the speed of light and makes real time adjustments to prevent harsh sounding and potentially speaker damaging clipping
Sentry Monitor™ - our fuse-less short-circuit protection circuit that disengages the output stage before current exceeds safe operating levels and then resets automatically when operating conditions return to normal
Quad Balanced design that cancels virtually all noise and distortion that may have crept into the audio signal
Power Control to send power on/off signals to other connected McIntosh components (such as CD Players, turntables, tuners and media streamers) for easy system power up and shutdown
Our patented Solid Cinch™ speaker binding posts that easily but securely attach the speaker cables to prevent them from coming loose and possibly causing a short; the binding posts are also gold-plated to prevent corrosion and ensure a quality signal is sent over your speaker cables
"It does everything right and nothing wrong, is built to last for generations, and sounds amazing no matter what speakers you connect to it." - Lyd & Bilde
The balanced and unbalanced outputs make bi-amping or tri-amping your speakers easier; they can also be used to send the audio signal to a secondary system if your preamplifier does not have enough outputs, or to connect a powered subwoofer. The MC462 sits on a beautiful polished stainless steel chassis and features the timeless McIntosh black glass front panel, illuminated logo, control knobs, aluminum handles and a pair of fast responding blue Watt meters.
***** Also advertised elsewhere ******
  • Like 4
  • Love 1
I know they are listed separately, but what a perfect match for the Olympica III s that are also for sale. Very good buying here for someone. GLWTS
  • Thanks 1
