agelessgoodguy Posted May 2, 2024 Posted May 2, 2024 Wear has come to bite my Marantz remote (RC027SR) controller's volume up section, is it repairable do you know team? thanks.
ray4410 Posted May 2, 2024 Posted May 2, 2024 you could try opening it up and cleaning the contacts on the board and rubber button pad there is also a carbon pen you can get online to restore the worn pads.
agelessgoodguy Posted May 2, 2024 Author Posted May 2, 2024 2 hours ago, ray4410 said: you could try opening it up and cleaning the contacts on the board and rubber button pad there is also a carbon pen you can get online to restore the worn pads. Thanks for this interesting info which I will follow Ray 1
ray4410 Posted May 2, 2024 Posted May 2, 2024 32 minutes ago, agelessgoodguy said: Thanks for this interesting info which I will follow Ray https://mektronics.com.au/products/circuitworks-rubber-keypad-repair-kit
