andylovesaudio Posted September 2, 2024 Posted September 2, 2024 Hi Guys, I’m seeking recommendations for 12v LPS … up to sgd200. It’s for a switch between my router and streamer/dac. Any feedback on the Teradac CM-30? Thanks for your help.
RussB Posted September 2, 2024 Posted September 2, 2024 I used to have another variant of this power supply and found it provided a very clean, spacious, sound but the timbres and harmonics were poor in comparison to a more expensive Geiseler power supply. A used Geiseler psu might be a good way to go if you can find one within budget.
MrBurns84 Posted September 2, 2024 Posted September 2, 2024 48 minutes ago, RussB said: I used to have another variant of this power supply and found it provided a very clean, spacious, sound but the timbres and harmonics were poor in comparison to a more expensive Geiseler power supply. A used Geiseler psu might be a good way to go if you can find one within budget. I also second the Gieseler power supply. Well built and local support is a plus too. Id be careful with ones bought off Aliexpress, as the transformers on some of them can be noisy and hum, especially the cheap ones. 2
andylovesaudio Posted September 5, 2024 Author Posted September 5, 2024 Thanks very much for your help. Really appreciate it. 1
