AshC90 Posted September 15, 2024 Posted September 15, 2024 Afternoon, Tinkering has got the better of me and looking at a speaker cable change, unsure what have positive user recommendations and advice sought on options. Currently have 4 x 2.5m runs of bi wired van den hul d352 hybrid. Looking to move those to a good home and simplify to 1.5m custom runs if I can, with jumpers. Budget under $600. Setup is a rotel ra-1572 amp, dmp-a8 streamer dac, and monitor audio silver 300 towers, streaming dance, pop genres mostly. Nothing I am trying to address, quite like the current sound (finally) which is detailed and analytical without being too fatiguing - which has been an issue in the past. A tad more fullness and weight low down maintainly clarity and detail would be a bonus. A change may work or not, part of the fun Audio principe look within budget and some tellerium a black II in the classified piqued initial interest
ray4410 Posted September 15, 2024 Posted September 15, 2024 Aurealis spiral 8 would be a great match it does all the things you are after. 3
AshC90 Posted September 16, 2024 Author Posted September 16, 2024 On 15/09/2024 at 6:51 PM, ray4410 said: Aurealis spiral 8 would be a great match it does all the things you are after. Thank you for the reply - they do look lovely, will make some enquiries and see if the budget stretches. 2
grammefriday Posted September 28, 2024 Posted September 28, 2024 I have a Rotel 1592 amp and use the tellurium q black ll cables with bookshelf speakers and am happy with the sound
AshC90 Posted September 28, 2024 Author Posted September 28, 2024 That’s good to know thanks, when they popped up in classifieds that prompted my interest actually, next time maybe what bookshelf speakers for reference @grammefriday? I ended up trying Audioprincipe bi wire cables as a half affordable highly recommended option, they are noticeably more detailed and sharper edges, more than expected actually, however for my combo and room just a little too much at present, will give them a fortnight to hopefully soften a little and make a call on them.
grammefriday Posted September 28, 2024 Posted September 28, 2024 My speakers are Lenehan Audio ML1 i have audio principe xlr cables from my cd to the amp and quite like them. If you bought from Peter you can return them within 14 days I believe
AshC90 Posted September 28, 2024 Author Posted September 28, 2024 Lovely, yes I wish I knew about his cables sooner for all others, would much rather support an individual in the community, will make the call on these ones soon as you say, thanks for your input
grammefriday Posted September 28, 2024 Posted September 28, 2024 You could also consider Robertson Audio Cables or NB speaker cables as other options
AshC90 Posted September 28, 2024 Author Posted September 28, 2024 Many thanks, wasn't aware of either of those
075Congo Posted February 22 Posted February 22 A shout out for the SILVERLINE Mk 2 Interconnects and the recently released ZEN speaker cabling created by Mark at SONIC ART in Melbourne. Really excellent products.
AshC90 Posted February 22 Author Posted February 22 Thanks Congo - after sampling a couple of options have settled on the Robertson audio interconnects and speaker cables 1
AshC90 Posted February 23 Author Posted February 23 (edited) 3 minutes ago, grammefriday said: Which interconnects did you go with in his range? Just the diamond range XLR Edited February 23 by AshC90 2
075Congo Posted February 23 Posted February 23 I would be very careful re the length of speaker cabling you order. Any cables under 2.5 meters are almost "un-resellable "when you change cables. Just a point!
