HI All,
After buying a Shanti dual linear power supply for my raspberry pi roon endpoint and Topping D30 dac and discovering the exciting improvements it made to overall sound. I would like to experiment with my PC that runs the Roon Core but it also supplies multichannel music too my AVR. What would the recommendations be?
9 minutes ago, powerav said:
HI All,
I would recommend you use a normal switching power supply.  There are no roon related analogue audio components in the PC, and you're probably sending digital to the AVR as well?
2 hours ago, Snoopy8 said:
The photo looks like a mock-up, with the stuff attached to the end of the heatsink instead of where you get the best heat dissipation. But I like the idea of passive cooling. I'll keep an eye on these when they are released in a unit (or become available like the OPTIMO DIY).
4 hours ago, Snoopy8 said:
p/s I use Intel NUC with 12V DC input.  Much easier to find LPS.
Have a read correctly that the NUCs don't do multichannel audio?
An NUC is a fully fledged PC.  They will do multi channel audio (and one day I may experiment if Zidoo does not work out).
I just thought I read something somewhere that they don’t do multichannel audio with Roon, I do have a nuc floating around and that’s the reason I didn’t use it, I may be wrong but I’ll do some research.
Multi channel is a function of O/S used on NUC. According to this, if you load Roon Bridge, it should do multi channel
https://help.roonlabs.com/portal/en/kb/articles/multichannel
