Camac Posted October 5, 2024 Posted October 5, 2024 Hello I have recently purchased a PS Audio system that requires some decent power cables. I need 7 with varying lengths to power the components I have. Where can I order all in one go, the varying lengths I need, with Oz 3 pin plugs fitted ( 15amp cable I assume is the norm with 10 amp earth pin ), are nice and flexible and have a good reputation without breaking the bank. I know there are some good cables out there for sale but mostly singles with the wrong pin plug. Thanks in advance, much appreciated.
Avo8 Posted October 5, 2024 Posted October 5, 2024 I replace a lot of fixed leads and often use these (but from WES Components their trade site, same product) with suitable cable glands. Though you will need to be licensed or hire someone. https://www.wagneronline.com.au/acl135/ps/ They will have 3 pin to IEC etc too as well as double insulated two pin versions. Short leads don't need to be "15A" cable. 1mm copper is fine or 0.75 on low power stuff. Unless you have a giant amplifier that's rated 15A. (have seen them in older stage P.A. stuff years ago.)
Camac Posted October 5, 2024 Author Posted October 5, 2024 Ok so what cable and fittings in particular are you suggesting? Thanks
Weka Posted October 6, 2024 Posted October 6, 2024 (edited) I would suggest you support local manufacturers and contact EGM Audio or Sonic Art for your power cable needs. I believe they can custom make to your requirements from their range, and they should also be compliant to the Australian Electrical Safety Standards. Edited October 6, 2024 by Weka Faulty URL link 1
grammefriday Posted October 6, 2024 Posted October 6, 2024 Audio Principe, EGM or Robertson Audio Cables all have quality power cords in addition to interconnects at reasonable prices 2
