Hawkeye Posted November 11, 2024 Posted November 11, 2024 Good afternoon SNA’ers This is the woofer from my OSBORN centre/active sub combination. I am trying to find the specs on this in particular the qts value. It’s a 15” I think possibly made in Taiwan. can anyone please help. Cheers.
VanArn Posted November 11, 2024 Posted November 11, 2024 It is more likely to be an early Focal woofer similar to their Audiom range, such as the 15KX model.
Hawkeye Posted November 11, 2024 Author Posted November 11, 2024 Thanks VanArn, I’ll do some more research.
VanArn Posted November 11, 2024 Posted November 11, 2024 I found out a little later from my post that Lyeco is a Taiwanese company. I am not sure if there is a connection between them and Focal.
Sub Sonic Posted January 16 Posted January 16 A little late to the party here but I believe there were/are some decent copies of focal drivers which some speaker manufacturers used at one stage - this may well be one of them.
