  • Volunteer
Looking for some advice on a portable battery-powered Bluetooth speaker. It would be used in my ancient car that has no connectivity.
I’ve looked at the Ultimate Ears and JBL offerings but no idea if they are any good.
Also not looking to spend much more than ~$100
I have liked a JBL Charge 3 I have had for some time now.  A bit bass heavy - but that's a good thing in a car where the bass often gets lost in the road noise.
I bought a JBL Flip 5 for Mrs A to use in her "craft" room.
I am impressed.  It was cheap (~$50) and easy enough to set up.  Sounds good to me considering how small the actual driver must be.
Superceded by newer model so should be attractively priced on runout.
The latest model Flip 6 is closer to $100, I think.
  • 1 month later...
Do you need microphone capabilities for hands-free calls, or purely speaker(s) for listening to music (or other sounds) from a Bluetooth device?
  • Volunteer
No I don’t.
Ended up getting the JBL Flip 6 on special from JB Hifi.
Must say it’s not great. I’m surprised at how good the bass is for such a small device but even in a noisy car setting the top end is a bit overdone.
I believe there’s an app that allows some eq but I haven’t tried it yet
Err, Zingalingalonga, you do know that you can take that old jalopy of yours into a car audio joint and get a nice after market screen fitted into the dash that'll do all your BT needs(Google maps so you don't get lost when out at Epping, for instance...).
Cheap and nasty BT speaker or cheap and nasty hard wired speakers.  Cost is bugger all
