Hi all wanting advice on removal of tweeters from Audio Definition Statis speakers they are covered with a type of slightly porest type of Lino and glued down .I was thinking maybe a hot air gun with protection for tweeters.I don’t want to damage the cover as I’d like to keep them original but need to change faulty tweeter .any advice would be appreciated
  On 31/12/2024 at 10:06 AM, Jodie 66 said:
Thanks I might have to give the hot air gun a go
Expand
Hair dryer perhaps, from the pictures, it looks like foam ?
Hi all thanks for help I managed to get them off just today by using just a plastic flat scraper as I was worried about heat gun doing damage.I’ve got 2 repair kits on the way from England thanks Jodie
  • Like 4
