jmouss Posted January 14 Posted January 14 (edited) Hey everyone. A couple days ago I bought the new marantz and I got to say its a beautiful amp. It's hooked up to my s90d samsung oled, and if anyone is looking for a new tv , trust me get the s90d. Now the issue I'm having is I've hooked up my fetch box to the aux1 input on the marantz and my fire tv to cable/sat. Now when I press aux 1 for the first time after turning on the tv, fetch is working fine. But then if I then for example switch to cable then switch back to fetch again after a couple of minutes ,it always says that it's not connected. But then I turn the fetch box on and off and it returns. Does anyone have a clue to what's going on? I've tried other inputs on the marantz and it's the same thing. It only does this with the fetch box. Also if i take out the hdmi cable and put it back in, the fetch comes back on again as well Edited January 14 by jmouss
Lil Caesar Posted January 14 Posted January 14 Try an alternative and/or better hdmi cable - v2.1 if you’ve got one, which supports 48Gb bandwidth for 8k, etc. overkill I know but I reckon this is your culprit.
jmouss Posted January 14 Author Posted January 14 Thanks caesar. I'll try that, the thing works only when I turn it off and on again. It's doing my head in.
