Hi, I've been thinking of adding a wiim pro to my setup .
I have a mission 778x which I stream to via bluetooth but I think I'll get better sound with the wiim and I belive they have room correction software but does it only work with a I phone ?
I am currently using the WiiM Pro with a external DAC if you are only going to use it on its own the on board DAC isn’t very good I would recommend you get the WiiM Pro Plus that has a very good built in DAC in that case or get a external DAC and pair it up with the WiiM Pro, both models have the room correction built in and is very good and easy to use.
