Item: ME 850 Stereo Power Amplifier
Price: $1,800
Reason for sale: Too many amplifiers
Payment: Bank transfer, COD
Extra info:    Legendary Australian Power Amplifier
I've owned most of the ME Power Amps and I think the 850 is the best of them, with the Best Bass of
any amplifier I've heard
Had Full Service 2 years ago by Ron Berger from Winovate in consultation with Peter Stein
Sonically perfect
Power: 2 x 120 Watts RMS  @ 8 Ohms
            2 x 200 Watts RMS  @ 4 Ohms
            2 x 360 Watts RMS  @ 2 Ohms
Minimum Recommended Load:  0.5 Ohmn
Max Output Current: 70 Amps
Frequency Response: DC - 150 KHZ +_ 2dB
Immense 2KVA Quadfilar Power Transformer
Class A Operation to 8 Watts
52 High Current Capacitors giving an unmatched 245,000 uF of Energy Storage
38 kg
post-140568-0-71129000-1433762598_thumb.
post-140568-0-56256200-1433762628_thumb.
post-140568-0-51862700-1433762665_thumb.
post-140568-0-82079800-1433762725_thumb.
post-140568-0-13305400-1433762762_thumb.
You, Sir, must have some cracking amps in your collection if this is the one you're letting go. I'd say GLWTS but I doubt you're going to need that!!
Guest Muon
What is meant by the "unmatched"? ...
It is just meaning that it has a heap of capacitance storage for the power supply.
Nice amp.... GLWTS
the "unmatched" part of the specifications has to be read in context - this is a 20yr old design, back then there were very few amplifiers that employed such overbuilt power supplies.  Nowadays, this isn't so uncommon.  Very nice amplifier which should continue to give very good service for another decade or so.
Actually, it is still incredibly rare, even in high end designs. I should add that the energy storage matrix employed by ME, is comprised of custom manufactured, very low ESR, very low ESL capacitors. Such an array where ripple current is shared by a large number of high ripple caps, combined with the cool air which is drawn past the capacitors, ensures a very long life.
Aaaagghhhh - dream amplifier to match my NS1000M's located just up the road!!!
If only I had access to lots of money - - @@Yamaha Man ????  :D
Would you need such a beast for NS1000's?
Ive heard them sing with low wattage single ended tubes ;)
Lovely amp by the way, very surprised it hasn't sold!
Edited by b@ndicoot
Run mine with a 40W / channel toob amp and just enough I think which equates to around a 100W S/S so this high Current amp at 120W would be good!  :thumb:
My word.  It's been almost 24 hours since this came up and it still hasn't sold.  I've always thought that the 850 was the "sweet spot" in ME's amp lineup.  GLWTS, a great amp at a very good price.
Read somewhere that ME power amp should be paired with ME pre-amp to bring the best out of it.
Does it mean ME power amp is difficult to match with other brand pre-amp?
What about Cambridge Audio Azur 840E pre-amp, anyone?
I can't see why that would be a problem as long as the input-output impedance matching was okay.
But why settle for less than ME?
ME 850 and its series is the only power amps I know with low input impedance, apparently they decided to have a low input impedance for sonic reasons, so a matching ME preamp with low output impedance is the way to go, however I've been informed that the input impedance can be raised with a modification at the expense of Slight reduction in SQ.
Any high end, low output impedance preamp will work just fine with the ME850. ME preamps tend to offer a lot more bang for your Buck though. For those who use poorly designed preamps (ie: Those which exhibit a high output impedance), the ME850 can be modified to operate with such preamps, though there will be slightly compromised performance.
Not all ME power amps employ a low input impedance. Some (ME50, ME100, ME75, ME150, ME200, ME550-II, ME555) employ a high input impedance as standard. ME's very best power amps, however, all employ a low input impedance (which can be adjusted up to 68,000 Ohms, if required).
The output impedance of the 840E is a rather high, 100 Ohms (less than 10 Ohms is desirable for ANY preamp in ANY system, not just those used with ME power amps. That said, the output impedance of the 840E is significantly lower than many, badly designed, preamps. It will work fine with an unmodified ME850, though for best operation, the ME850 should be modified for the 15,000 Ohm input impedance with that preamp.
Edited by Zaphod Beeblebrox
Any high end, low output impedance preamp will work just fine with the ME850. Me preamps tend to offer a lot more bang for your Buck though. For those who use poorly designed preamps (ie: Those which exhibit a high output impedance), the ME850 can be modified to operate with such preamps, though there will be slightly compromised performance.Not all ME power amps employ a low input impedance. Some (ME50, ME100, ME75, ME150, ME200, ME550-II, ME555) employ a high input impedance as standard. ME's very best power amps, however, all employ a low input impedance (which can be adjusted up to 68,000 Ohms, if required).The output impedance of the 840E is a rather high, 100 Ohms (less than 10 Ohms is desirable for ANY preamp in ANY system, not just those used with ME power amps. That said, the output impedance of the 840E is significantly lower than many, badly designed, preamps. It will work fine with an unmodified ME850, though for best operation, the ME850 should be modified for the 15,000 Ohm input impedance with that preamp.
I gather that input impedance modification cannot be done by the average person.
Although it is not difficult, it is not recommended. It should be performed by a tech, particularly with older models. One slip and the amp is toast.
All fascinating and I appreciate in response to a potential purchaser's question, but the OP is selling a fantastic Australian power amplifier at a very competitive price... so let's stay focused on that.
@@wildragon The Azur 840E is very capable and I have no doubt would be capable of driving the ME850 well... and Trevor has stated that "It will work fine with an unmodified ME850", and nobody is likely to know more about how ME gear plays than Trevor.
As a bonus, the ME850 at this price isn't likely to lead to any money down the drain if you decide to flip it again.
@@SirJack - good luck with the sale, not that you'll need it.
